Three different options exist to do boot loader installation or upgrade:
The latest boot loader SW can be found here. Depending on the upgrade approach chosen (ST-link, DFuse, USB-Stick) you need to either use the
For a very first boot loader installation (e.g. just after assembling the OVI40 UI board) you need to use the “P6 jumper” method, see below. Subsequent upgrades do not require this jumper closed anymore.
Please refer to the next sections for more details
Close P6 jumper in case:
After closing jumper “P6” continue with Option 1 (ST-Link) or option 2 (Defuse Tool)
After upgrade please remember to remove jumper P6 again!!
ToDo
ToDo
ToDo
Remove Jumper P6 if previously closed, then boot UI.
When booting the OVI40 UI a correctly installed boot loader will show this splash screen:
Please also check boot loader version number displayed in system menu corresponds to the version you intended to install.
Forum:
Github Wiki:
