en:operations:uhsdrops
  • Switch off OVI40UI
  • Press and hold push buttons F1 F3 F5
  • Switch on OVI40, wait for text message, release F1 F3 F5
  • Press simultaneously Band+ and Band- buttons to confirm resetting of settings
  • When UHSDR has bootet up long-press System Menu (F1 button) to save values
Hint:
If you just want to play around with default setting without loosing your own configuration:
  • do NOT press MENU long
  • do NOT switch off via power button because that stores active settings to EEPROM - just pull off power supply.
  • en/operations/uhsdrops.txt
  • Last modified: 17.02.2018 11:43
  • by df9ts
