UHSDR Operations
Reset all settings to default
- Switch off OVI40UI
 - Press and hold push buttons F1 F3 F5
 - Switch on OVI40, wait for text message, release F1 F3 F5
 - Press simultaneously Band+ and Band- buttons to confirm resetting of settings
 - When UHSDR has bootet up long-press System Menu (F1 button) to save values
Hint:
If you just want to play around with default setting without loosing your own configuration:
- do NOT press MENU long
 - do NOT switch off via power button because that stores active settings to EEPROM - just pull off power supply.
