en:ovi40_uiboardbuild
(can be used to build V1.8)
OVI40 UI schematics: uhsdr_ovi40_ui_v17_sheet.pdf
OVI40 UI PCB bottom layer: uhsdr_ui_ovi40_bst_bot_layer_17.pdf (component location searchable as text)
OVI40 UI PCB top layer: uhsdr_ui_ovi40_bst_top_layer_17.pdf (component location searchable as text)
OVI40 UI BoM: OVI40 UI BoM
  • en/ovi40_uiboardbuild.1515938253.txt.gz
  • Last modified: 14.01.2018 13:57
  • by df9ts
