Building the UI V1.8 Board
OVI40 UI V1.7 Documents
Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component's location by entering the component reference (e.g. “R20”) in pdf search.
OVI40 UI V1.8 Documents
OVI40 UI V1.8 Kit Contents
Assembly and Soldering
Please read Errata carefully
IC Device Markings
BAV70 | A4 | D5, D6 | Diode |
MCU STM32 "Pin 1" marking
Comparison of MCUs:
RAM [kB] | 192 | 512 | 1024 |
Clock[MHz] | 168 | 216 | 400 |
Pins | 100 | 144 | 144 |
DMIPS | 210 | 462 | 856 |
EEPROM IC7 orientation
Polarised capacitors
- “mcHF style”: S7 and S8 not line with switches under LCD - they are mounted slightly higher
- “OVI40 style”: S7 and S8 are mounted in line with the function keys under the LCD
Modifications
Symptom: In stand-by the current drawn from back-up battery is excessively high.
Work-around: Put resistor in parallel to C94. Start with a value of 56k - this seems to work in most cases. If board does not start increase value slightly.
Change brightness of LEDs
- R36 auf 22,6k (D1 grün)
- R37 auf 6,8k (D2 rot)
- R116 auf 6,8k (D3 blau)
