Building the UI V1.8 Board
OVI40 UI V1.7 Documents
Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component's location by entering the component reference (e.g. “R20”) in pdf search. No need to be concerned to use the V1.7 component placement doc for assembling a V1.8 UI board - V1.7 and V1.7 are quite similar in this respect.
OVI40 UI V1.8 Documents
OVI40 UI V1.8 Kit Contents
Assembly and Soldering
Please read Errata carefully
=== IC Device Markings ===
MCU STM32 "Pin 1" marking
=== STM32F76X_ZIT vs. STM32H743ZIT6 ===
Comparison of MCUs:
| Clock[MHz] | 168 | 216 | 400 |
| Pins | 100 | 144 | 144 |
| DMIPS | 210 | 462 | 856 |
EEPROM IC7 orientation
Polarised capacitors
- “mcHF style”: S7 and S8 not line with switches under LCD - they are mounted slightly higher
- “OVI40 style”: S7 and S8 are mounted in line with the function keys under the LCD
Modifications
Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: Put resistor in parallel to C94. Start with a value of 56k - this seems to work in most cases. If board does not start increase value slightly.
Change brightness of LEDs
- R36 auf 22,6k (D1 grün)
- R37 auf 6,8k (D2 rot)
- R116 auf 6,8k (D3 blau)
