Building the UI V1.8 Board
OVI40 UI V1.7 Documents
Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component's location by entering the component reference (e.g. “R20”) in pdf search. No need to be concerned to use the V1.7 component placement doc for assembling a V1.8 UI board - V1.7 and V1.7 are quite similar in this respect.
OVI40 UI V1.8 Documents
OVI40 UI V1.8 Kit Contents
Assembly and Soldering
Please read Errata carefully
=== IC Device Markings ===
MCU STM32 "Pin 1" marking
=== STM32F76X_ZIT vs. STM32H743ZIT6 ===
Comparison of MCUs:
| Clock[MHz] | 168 | 216 | 400 |
| Pins | 100 | 144 | 144 |
| DMIPS | 210 | 462 | 856 |
EEPROM IC7 orientation
Do not solder in R101 for the EEPROM delivered with the kit (AT24CM02).
Polarised capacitors
- “mcHF style”: S7 and S8 not line with switches under LCD - they are mounted slightly higher
- “OVI40 style”: S7 and S8 are mounted in line with the function keys under the LCD
IC9 und IC11: leave empty for now
IC9 (SPI FRAM) and IC11 (SPI FLASH) are for future use. Please leave empty for now. They are neither required nor supported by UHSDR at this time.
Device Electronic Signature
STM32F76xxx
- 0x111: STM32F767 and STM32F777 LQFP208 and TFBGA216 package
- 0x110: STM32F769 and STM32F779 LQFP208 and TFBGA216 package
- 0x101: STM32F767 and STM32F777 LQFP176 package
- 0x100: STM32F769 and STM32F779 LQFP176 package
- 0x011: WLCSP180 package
- 0x010: LQFP144 package
- 0x001: LQFP100 package
- 0x000: Reserved
STM32H7x3 MCUs:
- 0000: LQFP100 (STM32H7x3)
- 0010: TQFP144 (STM32H7x3)
- 0101: TQFP176/UFBGA176 (STM32H7x3)
- 1000: LQFP208/TFBGA240 (STM32H7x3)
Modifications
Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: Put resistor in parallel to C94. Start with a value of 56k - this seems to work in most cases. If board does not start increase value slightly. The same approach is used BTW in the commercially available Disco F746 prototype board.
Change brightness of LEDs
- R36 auf 22,6k (D1 grün)
- R37 auf 6,8k (D2 rot)
- R116 auf 6,8k (D3 blau)
