Ordering
OVI40 UI board and Display module
OVI40 UI board and display board can be ordered here
The kits will require SMD soldering.
For the OVI40 UI board there are 3 order options:
- bare PCBs - you provide the components yourself
- kit - containing PCBs and all required components
- soldered and tested UI boards, ready to use
The display board is offered as soldered and tested module, ready to plug into OVI40 board.
The rf board is still under development and cannot be ordered at this moment. Please note that mcHF RF boards upto and including V0.6 are compatible with OVI40 Ui board and can be used also.
