OVI40 short description
The OVI40-SDR was inspired by the mcHF SDR project. Compared to the mcHF the OVI40-SDR has implemented some major hardware improvements. The OVI40-SDR is using a much more powerful MCU with more processing power, RAM and Flash ROM. The software running on the OVI40-SDR is the UHSDR software which takes full advantage of the evolving OVI40-SDR features. Both projects - OVI40-SDR and UHSDR - are initiated by the same group of hamradio amateurs and both are in active development. Due to mcHF hardware limitations a sub-set of UHSDR runs also on the mcHF.
The OVI40-SDR Hardware is covered by the OVI40-SDR project. The Software is covered by the UHSDR project.
The OVI40-SDR is currently in development. The processor- and UI board is already available. The RF board is in the final stages of development with beta-testing starting soon. Both projects - OVI40-SDR and UHSDR - will continue to stay in active development as they did for the past.
OVI40-SDR Hardware
Hamradio Transceiver for the following ham bands:
- 135 kHz & 472 kHz
- 160m, 80m, 60m, 40m, 30m, 20m, 17m, 15m, 12m, 10m
- 6m, 4m, 2m
Note: ToDo: Change screen shot to recent UHSDR screen shot
The transmit power is designed to be 50 W (software controllable). The OVI40-SDR is a true SDR “Software Defined Radio”. It contains a STM32 microcontroller with LCD touch-screen display panel and enables operation as stand-alone rig without the need for additional laptops / PCs etc. Aufgrund dieser Architektur sind wesentliche Leistungsmerkmale nun nicht mehr alleinig in der Hardware begründet. Erst die Software, UHSDR, die auf dem Microcontroller läuft (auch “Firmware” genannt), gibt dem Gerät seine Leistungsstärke und Funktionsvielfalt. Die auf dem Spektrum maximal sichtbare Bandbreite beträgt zur Zeit 48KHz, das wird in Zukunft aber noch mehr werden. Man kann in Signale hineinzoomen bis auf 1/32 der maximalen Bandbreite. Die Anzeige kann auch von Spektrum auf Wasserfall umgeschaltet werden, und es können Spektrum und Wasserfall gleichzeitig dargestellt werden. Es wird mit 12…16V Versorgungsspannung betrieben und lässt sich so sehr gut portabel oder mobil mit Batterien / Akkus betreiben. Die Bedienung ist intuitiv und erfolgt sowohl mit dem Touchscreen als auch mit Tastern / Drehcodierern, was ein echtes “Funkgerätefeeling” aufkommen lässt. Das umfangreiche Service- und Konfigurationsmenü ist ebenfalls per Taster und Drehschalter bedienbar. Die folgenden Modulationsarten werden standalone ohne PC unterstützt:
- LSB, USB, AM, AM synchron (Spezielle Doppelseitenbandempfangsart für AM)
- FM (mit Subtonauswertung!)
- FreeDV
- CW (mit integriertem CW-Decoder)
- RTTY
- PSK / BPSK
- 300Hz, 500Hz, 1.4KHz, 1.6KHz, 1.8KHz, 2.1KHz, 2.3KHz, 2.5KHz, 2.7KHz, 2.9KHz
- 3.2KHz, 3.4KHz, 3.6KHz, 3.8KHz, 4.0KHz, 4.2KHz, 4.4KHz, 4.6KHz, 4.8KHz, 5.0KHz
- 6.0KHz, 6.5KHz, 7.0KHz, 7.5KHz, 8.0KHz, 8.5KHz, 9.0KHz, 9.5KHz, 10KHz
… teilweise mit mehreren wählbaren Mittenfrequenzen oder als Tiefpass. Ein vom User zur Laufzeit veränderbares Filter ist bereits angedacht.
Zusätzlich ist eine “spektrale Noisereduction”, ein automatischer Notchfilter, ein manueller Notchfilter, ein manuelles Peak-Filter und ein Noiseblanker integriert. Die Leistung des NR kommt in gleiche Höhen wie die bekannter externer “Sprachextraktoren”. Im Sendebetrieb kann das Audiosignal digital komprimiert werden - der Kompressionsgrad ist per Drehknopf jederzeit veränderbar. Für CW-Fans ist binauraler CW-Empfang sowie ein Keyer mit den beiden Curtis-Modes “A” und “B” sowie dem Ultimatic-Mode bereits in der Firmware integriert. Die Abstimmschrittweite ist von 1Hz…100KHz in Zehnerpotenzen (Zusatzstufen für 500Hz und 5KHz) einstellbar. Es ist auch dynamisches Tuning integriert (Schrittweite ändert sich mit der Drehgeschwindigkeit am VFO-Knopf). Auch eine Abstimmung via Touchscreen ist integriert: man tippt einfach auf ein Signal im Spektrum oder Wasserfall und der VFO wird sofort auf diese Frequenz abgestimmt.
Das Gerät speichert pro Band die jeweils letzten Einstellungen (Betriebsart, Frequenz, Bandbreite etc.) Dadurch ist beim schnellen “Drehen über die Bänder” stets eine aktuelle Einstellung vorhanden. Weitere Speicher (“Memories”) sind geplant. Diese werden dann auch auf eine SD-Karte gespeichert werden können, denn das Gerät besitzt einen integrierten Mikro-SDcard-Leser.
Das Gerät lässt sich mit einer einzigen USB-Verbindung zu einem PC mit CAT steuern. Es wird das Protokoll des Yaesu FT-817 emuliert. Parallel zur CAT-Schnittstelle wird über das gleiche Kabel eine USB-Audioverbindung (TX- und RX- seitig) angeboten. Der USB-Audioausgang des mcHF kann via Menü wahlweise auf echtes Audio oder I/Q - Audio umgeschaltet werden, so dass man mit einem externen SDR-Programm (wie z.B. HDSDR) Zugriff auf das komplette RX - Baseband hat. Programme für zusätzliche digitale Betriebsarten lassen sich mit nur einem USB-Kabel, über das dann ja sowohl CAT als auch Audio läuft, mit dem OVI40 verbinden.
Der OVI40-SDR zählt zu den wenigen Geräten, die die digitale Telefoniebetriebsart FreeDV bereits integriert hat. Damit ist FreeDV “gleich eingebaut” und zusätzliche Hardware wie Spezialmikrofone und/oder Computer sind dazu nicht nötig.
OVI40 RF Board
Das RFboard beinhaltet RF Vorverstärker, Mischer, lokaler Oszillator und HF Leistungsverstärker. Das RF Board besteht aus einer Trägerplatte, auf der sich diverse weitere Steckplätze befinden. Es wird über Pfostenstecker mit dem UI-Board verbunden. Durch den modularen Aufbau wird es möglich sein, bei Verbesserungen nur kleinere Platinen zu erneuern, anstatt dass die gesamte RF-Platine erneuert werden muss..
Die Entwicklung der RF-Platine ist noch nicht vollkommen abgeschlossen. Wesentliche Eckdaten ohne Anspruch auf Vollständigkeit:
- RX von VLF (~ein paar KHz) bis ~280MHz.
- TX 50 W auf allen Bändern von 160m…4m, auf 2200m, 630m und 2m (wenn dies mit implementiert ist) 10…20mW aus SMA Buchse
- mitlaufende Preselektion
- PA mit Doppel-LDMOSFET, einzeln eingestellte BIAS Ruheströme. Messung der BIAS Ruheströme über eingebaute A/D-Wandlern. Ruheströme können per UHSDR Software ausgelesen und eingestellt werden.
- TX und RX Mixer mit niedriger Kapazität (geringer Durchschlag des LO)
- echter RX QSD Detektor mit vier Instrumentenverstärkern
- Gewinnung der internen Spannungen (8V, 5V) mit abgeschirmten Schaltreglern, deren Schaltfrequenz per Software so gelegt wird, dass niemals eine Oberwelle der Schaltfrequenz im Empfangsspektrum liegt
- eingebaute Messbrücke mit logarithmischem HF Verstärker, um Antennen vermessen zu können (Real- und Blindwiderstand)
- auf SMA-Buchse herausgeführtes zusätzliches HF-Signal, das unabhängig vom Empfang eingestellt werden kann. Dieser kann z.B. füer eine WSPR Bake genutzt werden, die parallel und unabhängig vom Sender betrieben werden kann.
- Nutzungsmöglichkeit des TRX als Messgerät (Netzwerkanalyzer)?
- Transverterfähig
Wenn die Alpha-Entwicklungsphase abgeschlossen ist, werden die Informationen vervollständigt.
Frequenzaufbereitung
Der OVI40 arbeitet im Empfangsbereich bis 48 kHz als echter Direktsampler. Ab 48 kHz aufwärts arbeitet der Empfänger als QSD.
Entsprechend arbeitet der lokale Oszillator (LO) beim OVI40-SDR:
Nach Datenblatt geht der verwendete SI5351 LO maximal bis 160MHz. Auf vielen Seiten des Internets (unter anderem von QRP Labs) wurde aber herausgefunden, dass man so gut wie immer bis 292 MHz kommt. Dies hat DF8OE an 10 SI5351 (Erfolgsquote 100%) verifiziert.
Tranverternutzung
Transverter Einstellungen in der Software
Die UHSDR Software unterstützt bereits die Transverter Offseteinstellung. Dazu:
- 10m-Band (oder 20m Band) wählen als Transverterband
OVI40-SDR Transverter Hardware Support
Der OVI40 hat an diversen interessanten Schnittstellen die Signale an SMA-Buchsen herausgeführt. Die Buchsen sind nicht fest mit der RF-Platine verbunden, damit man Gehäuse-mäßig nicht eingeschränkt ist. Auf der RF-Platine bzw. den entsprechenden Modulen werden TE-Connectoren (U.FL "Norm") platziert sein, an die man bei Bedarf die entsprechenden Adapterkabel anschließen und irgendwo individuell an seinem Gehäuse verbinden kann.
