OVI40 Short Specification
OVI40-SDR Components
- UI Board
- RF Board
- Housing
UI Board
UI board table of features:
| PCB Dimensions: | 186mm x 66mm |
| Processor: | STM32F76x (216 MHz Clock), optional STM32H743ZIT6 (400 MHz Clock, pin compatible with STM32F76x) |
| Audio Codec: | 2 x WM8731 @ 96KHz (UHSDR currently using 48 kHz only), separate IQ and Audio (TX and RX possible simultaneously, RF board needs to support this) |
| Display: | 3.5“ 480×320 as default, 3.2” and 2.8“ supported |
| LCD Interface: | parallel and SPI supported, parallel used as default |
| Internal memory: | SPI-Flash (Option), SPI-RAM (Option) |
| External memory: | microSD card |
| Realtime clock: | integrated Realtime Clock (RTC) part of STM32 MCU, CR2032 Backup Battery |
| LEDs: | 3 |
| External connections: | Mini-USB Type B, USB-Host (USB-A), 3.5mm connector for microphone and PTT, 3.5mm connector for analog input, 3.5mm connector for analog output (line-out is independant from loudspeaker), 3.5mm connector for headset |
| Internal connections: | 30pin connector (mcHF RF Board compatible), 6pin GPIO, 25pin connector (GPIOs, SPI, I2C), ST-Link V2 compatible Debug connector, Debug output, 2 x 4 Pin internal USB connections |
| Keys: | 18 separate keys |
| Rotary encoders: | 4 rotary encoders with integrated key function |
| Audio output: | Stereo, 2 x 3W at 2 x 4 Ohm with less than 1% THD+N |
Display Board
Note: ToDo Photo
| Display size: | 3.5 inch |
| Display Type | TN |
| Resolution: | 480 x 320 |
| Controller: | ILI9846 (and compatible) |
| Human Interface: | Touchscreen |
| Interface: | SPI and Parallel |
RF Board
Housing
