Wiki ToDo
- Check why Discussion cannot be switched off per page
- Try to disable translation outdated warning
- UHSDR Beschreibung à la https://github.com/df8oe/UHSDR/wiki/Technical-Specifications-of-mcHF
- UI Board Blockdiagram based on OVI40 UI schematics, style example here
- Inbetriebnahme
- Align German and English versions of uiboardtest
- Check tags used actually, compare with page overview for gaps
- In uhsdr:uhsdrtroubleshooting complete debug cable with trace output TRACESWO
- Implement language detection https://www.dokuwiki.org/tips:browserlanguagedetection - use browser language detection to automatically to switch to en fr de (the languages currently used in wiki) all other should go to English?
- Add STM32 device signatures for F7 H7 and F4 used https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=1025;start=0#lastPost
Stub Seiten - diese Seiten müssen noch erstellt werden
| UHSDR Operations | 15.02.2018 15:58 | english, stub |
| RF Board Assembly | 08.02.2018 20:42 | english, stub |
| Display Test & Trouble Shooting | 16.05.2020 07:37 | english, stub |
| Help and Support | 07.02.2018 07:26 | english, stub |
| RF Board Test & Fehlersuche | 07.02.2018 15:36 | english, stub |
| Pull UHSD source code from Github | 18.02.2018 08:46 | english, stub |
| Assemblage RF Board | 08.02.2018 20:40 | french, stub |
| Aide et soutien | 12.02.2018 14:43 | french, stub |
| Tests et diagnostiques OVI40 RF board | 12.02.2018 14:28 | french, stub |
| UHSDR Bedienung | 16.01.2018 23:13 | german, stub |
| Nachbau RF Board | 15.01.2018 01:08 | german, stub |
| Display Test & Fehlersuche | 15.01.2018 15:49 | german, stub |
| Hilfe und Support | 17.01.2018 11:47 | german, stub |
| RF Board Test & Fehlersuche | 15.01.2018 15:49 | german, stub |
Fehlende Info auf diesen Seite ergänzen
| OVI40 Short Specification | 20.01.2018 20:15 | english, missinginfo |
| OVI40 - déscription brève | 09.02.2018 13:33 | french, missinginfo |
| OVI40 Kurzdaten | 15.01.2018 00:54 | german, missinginfo |
Seiten fertig zum Review
Seiten ok
Include Seiten
| Wissen ist das einzige Gut, das mehr wird, wenn man es teilt. | 19.01.2017 17:30 | german, publish, include |
| Know-how is the only thing that is multiplied by sharing it | 25.09.2017 12:14 | english, publish, include |
| Wiki ToDo | 07.02.2018 21:38 | english, include |
| La connaissance est le seul bien qui s'enrichit quand vous le partagez | 26.11.2017 05:35 | french, publish, include |
| Wiki ToDo | 08.02.2018 06:06 | french, include |
| UHSDR development - Build using eclipse | 08.02.2018 06:08 | english, publish, include |
Autogenerate Seiten
