In General
2do…
2do…
  • place a rich amount of RMA-223 flux on all component pins
  • cut a handy length of desoldering braid and soak one end with solder
  • use this as kind of a “solder paintbrush”. Put a flat, screwdriver shaped tip on the iron and position it 5mm before the end of the soaked desoldering braid. Now use a perpendicular movement towards the pins. Thanks to capillary attraction the pins will be safely connected with their corresponding pads. This will also prevent a bending of single pins cause of the strict perpendicular movement. Step by step finish all the pin lines with that sponging technique movement. Shortings can be removed with clean desoldering braid and cold soldered spots can be removed with a short touch of the soldering iron.
Best practice is always to beginn with the most complicated component the STM32F7 / STM32H7. 99% of the work here is not the soldering, but as mentioned before, the correct positioning of the STM32 with his 144 pads. This needs to be done very precisely to avoid later problems. If the positioning is finished the following solder process as described before can be done in 1 to 2 minutes. The two audio codecs are placed on the pcb the same way. When finished all three components should be classically cleaned from remaining flux with isopropyl alcohol. All remaining SMD components will then follow on the component side (STM32 side). There is only one single component on the front side. Its recommended to finish one complete item from the list e.g. all 100nF/0603 then step to the next item e.g. all 0 Ohm resitors etc. This is only a recommendation and everybody can follow his own plan here of course. Soldering is finished with all wired parts (connectors, encoders, USB connectors, male- and female connector strips). In the first step the lithium battery should NOT be soldered onto the pcb. Recommendation for the connector strips is that connectors with electrical voltage and current should be kept female to avoid shortings. So the I40 UI pcb should have the male connector strips on it. Its very useful to keep that rule which makes testing with the RF boards of different owners very easy. If you use 24LC1025 serial EEPROM fit R101. For all other EEPROM versions leave it out.
The LCD display needs to be “treated” with a dremel driver or small coping or jig saw first. The supporting pcb must be cut at the upper, bottom and left side flush to the level of the LCD panel housing itself. The left soldering holes need to be cut off here. Holes or pins on the right side of the panel where the flat ribbon cable runs out need to mandatory kept ! On the left side where the soldering holes were cut off we have the potential danger that copper strips form the pcb were shortened by the metal frame of the panel. This can easily be avoided with a small piece of scotch tape. Lift the panel ca. 0.5mm very carefully with a cutter knife and place the scotch tape under it. Fold it over the pcb edge. If you do not have an LCD with double lines connector strips at the right end you need to place the connector strips with the long side of the pins from above (!) into the soldering holes. Solder them from the bottom side. This way you do not need to remove the plastic carrier which may damage the panel connectors. The short ends of the connector strip pins on the upper (plastic) side need to be cut off. Special attention need to be payed here to the very sensitive flat ribbon cable to not damage it. A damage will most likely end up in totaling the LCD. Attention should also be payed not to use to much solder to avoid little “humps” here which kept the panel connectors from connection flat to the their male counterparts on the UI pcb.
One picture says it all - a couplke of photos which show the fully populated UI pcb.:
Bringing the I40 UI pcb to work
The UI pcb can, and of course should be, tested first before connecting it with any RF board. (I40 UI is fully compatible to the original mcHF RF board.) The LCD panel should be left off here as well and jumper P6 needs to be bridged. Connect pin 30 of the connector strip with ground and pin 28 with +5V. The actual current should be clearly under 80mA. If not, supply voltage should be removed immediately and the pcb be checked for possible errors. If all is fine connect the small USB connector with a PC. Under Windows you hear the typical chime for new USB components and the taskbar shows an STM in DFU mode. Linux is a bit more silent here. Linux proofs with //dfu-util -l
if the STM32F7 can be seen. If yes bootloader and firmware can be flashed with: dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/bl-40SDR.dfu
und
dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/fw-40SDR.dfu
Windows users do the same with the well known “DfuSE Demo” tool from STM.
Actual firmware and bootloader can de downloaded here: [https://df8oe.github.io/UHSDR/|
If this was all successful then remove the supply voltage and also remove jumper P6. Put the LCD panel into its connectors and reconnect the +5V voltage to pin 28. You should now see the boot process with the UHSDR bootscreen and some error messages. These messages are expected, cause of the missing RF board.
  • en/projekte/ovi40-sdr/aufbautipps-ui-pcb.1508312923.txt.gz
  • Last modified: 18.10.2017 07:48
  • by df8oe
