BOM OVI40-SDR UI V1.724-09-2017DF8OE Distributor / Prices
IC8NCP5501DT50G5,0 Volt LDODPAK1170-33690,602TS 2940 CP50 863-NCP5501DT50G
D6BAV70Double DiodeSOT23.
D7BAS85Schottky barrier diodeSOD80C3146-93940,23BAS 85 SMD0,034771-BAS85135
D1greenLEDLED_3MM1276-49760,409LED 3MM ST GN 710-151034GS03000
D2redLEDLED_3MM1276-49770,361LED 3MM ST RT 710-151034RS03000
D3blueLEDLED_3MM1276-49750,443LED 3MM ST BL 710-151034BS03000
BAT1-HOLDER Battery Holder CR2032 1131-97492,98 BU2032-1-ND0,66
L147uHL_SMD1005L10053221-56550,13 810-MLZ2012M470WT000 MLZ2012M470WT0000,12
L247uHL_SMD1005L1005.
L347uHL_SMD1005L1005.
R147kSMD Resistor TK5008056 SMD-0805 47k0,02667-ERJ-U06F4702V
R1A100RSMD Resistor TK50060313 SMD-0603 1000,03667-ERJ-3RBD1000V
R1B0RSMD Resistor TK5006033 SMD-0603 00,03667-ERJ-3GEY0R00V
R21kSMD Resistor TK5006037 SMD-0603 1,0k0,03667-ERJ-S03F1001V
R3100RSMD Resistor TK500603.
R41kSMD Resistor TK500603.
R4B12R2SMD Resistor TK5012064 SMD ¼W 2,20,0371-CRCW12062R20FNEB
R4D2R2SMD Resistor TK501206.
R50RSMD Resistor TK500603.
R61kSMD Resistor TK500603.
R71kSMD Resistor TK500603.
R8100RSMD Resistor TK500603.
R94k7SMD Resistor TK5008054 SMD-0805 4,7k0,02667-ERJ-S06F4701V
R104k7SMD Resistor TK5006031 SMD-0603 4,7k0,02667-ERJ-3EKF4701V
R114k7SMD Resistor TK500805.
R124k7SMD Resistor TK500805.
R1347RSMD Resistor TK5006037 SMD-0603 470,03667-ERJ-3EKF47R0V
R1447RSMD Resistor TK500603.
R151kSMD Resistor TK500603.
R16100RSMD Resistor TK500603.
R17100RSMD Resistor TK500603.
R18100RSMD Resistor TK500603.
R19100RSMD Resistor TK500603.
R20100RSMD Resistor TK500603.
R2147RSMD Resistor TK500603.
R2247RSMD Resistor TK500603.
R230RSMD Resistor TK5008058 SMD-0805 00,02667-ERJ-U060R00V
R24680RSMD Resistor TK5008054 SMD-0805 6800,02ERJ-6ENF6800V
R254k7SMD Resistor TK500805.
R26100RSMD Resistor TK500603.
R27100RSMD Resistor TK500603.
R28100RSMD Resistor TK500603.
R291kSMD Resistor TK500603.
R300RSMD Resistor TK500805.
R310RSMD Resistor TK500805.
R320RSMD Resistor TK500805.
R33100RSMD Resistor TK500603.
R34100RSMD Resistor TK500603.
R35A4R7SMD Resistor TK5012061 SMD ¼W 4,70,0371-CRCW12064R70FNEB
R36680RSMD Resistor TK500805.
R37680RSMD Resistor TK500805.
R401kSMD Resistor TK500603.
R4147RSMD Resistor TK500603.
R452R2SMD Resistor TK501206.
R462R2SMD Resistor TK501206.
R4747RSMD Resistor TK500603.
R4847RSMD Resistor TK500603.
R1010RSMD Resistor TK500603.
R1080RSMD Resistor TK500805.
R1100RSMD Resistor TK500805.
R1120RSMD Resistor TK500805.
R1140RSMD Resistor TK500805.
R12047kSMD Resistor TK500805.
R12147kSMD Resistor TK500805.
R12247kSMD Resistor TK500805.
R12347kSMD Resistor TK500805.
R12447kSMD Resistor TK500805.
C10100nFSMD Chip Capacitor X7R060363 X7R 0603FCF 100N0,04
C1210uFSMD Tantal-ELKO 16VTA-B 3,5 x 2,89 T494B 10U 160,51
C244.7uFSMD Tantal-ELKOTA-A 3,2 x 1,61 T491A 4,7U 160,04
C811uFSMD Chip Capacitor NP0/COG0603.
C831uFSMD Chip Capacitor NP0/COG0603.
C93100nFSMD Chip Capacitor X7R0603.
C1071uFSMD Chip Capacitor NP0/COG0603.
C109220pFSMD Chip Capacitor NP0/COG06031 NPO 0603AAF 220P0,04
C1248,2pF – 10pFSMD Chip Capacitor06032 NPO-G0603 10P0,04
S1G3SMD Pushbutton KSC941J 18243-51570,64 611-KSC941JLFS CKN10433CT-ND0,55
S2G2SMD Pushbutton KSC941J .
S3M2SMD Pushbutton KSC941J .
S4BMSMD Pushbutton KSC941J .
S5G4SMD Pushbutton KSC941J .
S6M3SMD Pushbutton KSC941J .
S7SMSMD Pushbutton KSC941J .
S8SPSMD Pushbutton KSC941J .
S9M1SMD Pushbutton KSC941J .
S10F3SMD Pushbutton KSC941J .
S11F1SMD Pushbutton KSC941J .
S12F2SMD Pushbutton KSC941J .
S13F4SMD Pushbutton KSC941J .
S14BPSMD Pushbutton KSC941J .
S15F5SMD Pushbutton KSC941J .
S16G1SMD Pushbutton KSC941J .
J11503_07Audio Plug 3,5mm1503_073121-70162,26LUM 1503-070,59
Button CapCap whiteBTNKSC98010 CKN10427-ND0,27
JP36 Pin Board to BoardPinheader-1×061×064
P1SW_12VPinheader-1×021×026
JP8DEBUGPinheader-1×061×06.
LCD1 Pinheader-2×172×171
optional parts
IC9CY15B104QSPI FRAMSO08 727-CY15B104Q-SXI
IC11SST25VF04BSPI FLASH 2,7V, 4MbitSO08 SST 25VF040B0,97579-25VF040B504IS2AE SST25VF040B-50-4I-SAF-N0,82
  • en/projekte/ovi40-sdr/bom.1520760700.txt.gz
  • Last modified: 11.03.2018 09:31
  • by yd0rwo
