  • Option 1: Debug adapter approach. Preconditions:
    • STM “ST-Link V2” adapter, STM Link SW
  • Option 2: STM “Defuse” approach. Preconditions:
    • PC with STM Defuse Tool installed
    • USB to micro-USB cable (to connect PC with OVI40 mini-USB socket)
  • Option 3: USB-Stick approach. Preconditions:
    • USB stick with correct boot loader image
    • prior boot loader installation existing and working on OVI40 UI
  • *.bin file (pure binary file)
  • *.dfu file (containing binary and additional info such as target address on MCU)
Close P6 jumper in case:
  • There was never a UHSDR boot loader on the MCU (e.g. new assembled board)
  • Boot loader malfunctions, no upgrade with Defuse or USB-Stick possible
ToDo
Preconditions
  • Connect STM ST-Link V2 adapter to PC and to OVI40 UI.
  • ST-Link SW installed and running on PC, USB drivers installed, adapter recognized by PC
Procedure
Further Reading
ToDo
Preconditions
Procedure
  • Boot loader installation described here
Further reading
ToDo
Preconditions
  • OVI40 UI powered up with 5V and 8V (JP1). The 8V powers the USB stick via voltage regulator
Procedure
Note: ToDo
Bootloader laden
UHSDR Firmware laden
  1. +8V on JP1 pin 29 - zur Stromversorgung des USB stick!
  2. Drücke und (wichtig!) halte Taste “BAND -”
  3. +5V on JP1 pin 28 legen - um bootloader zu starten
  4. USB stick in USB port stecken - auf richtigen Firmware Namen achten (fw-40SDR.bin)
  5. Warten bis FW upload fertig ist
  6. Taste “Band -” loslassen
  7. +5V aus und wieder einschalten für OVI40 UI board reboot.
  • en/uhsdr/uhsdrbl.1517849916.txt.gz
  • Last modified: 05.02.2018 16:58
  • by df9ts
