Bootloader Installation - General Comments
- Option 1: Debug adapter approach. Preconditions:
- STM „ST-Link V2“ adapter, STM Link SW
- Option 2: STM „Defuse“ approach. Preconditions:
- PC with STM Defuse Tool installed
- USB to micro-USB cable (to connect PC with OVI40 mini-USB socket)
- Option 3: USB-Stick approach. Preconditions:
- USB stick with correct boot loader image
- prior boot loader installation existing and working on OVI40 UI
- *.bin file (pure binary file)
- *.dfu file (containing binary and additional info such as target address on MCU)
For a very first boot loader installation (e.g. just after assembling the OVI40 UI board) you need to use the „P6 jumper“ method, see below. Subsequent upgrades do not require this jumper closed anymore.
"P6 Jumper" Method for very first boot loader upgrade
Close P6 jumper in case:
- There was never a UHSDR boot loader on the MCU (e.g. new assembled board)
- Boot loader malfunctions, no upgrade with Defuse or USB-Stick possible
After closing jumper „P6“ continue with Option 1 (ST-Link) or option 2 (Defuse Tool)
Option 1: ST-Link upgrade
ToDo
Preconditions
Procedure
Further Reading
Option 2: DeFuse Tool upgrade
ToDo
Preconditions
Procedure
- Boot loader installation described here
Further reading
ToDo
Preconditions
- OVI40 UI powered up with 5V (Pin 28 JP1) and 8V (Pin 29 JP1) and GND (Pin 30 JP1). The 8V powers the USB stick via voltage regulator
Procedure
- Supply +8V on JP1 pin 29 - to pwer USB stick
- Push and - important - hold switch „BAND -“
- Supply +5V on JP1 pin 28 - this starts the boot loader
- insert USB stick into large USB port of OVI40 UI
- Wait for FW upload to finish
- Release switch „Band -“
- Remove +5V, then apply again to reboot OVI40 UI.
Check proper working of newly loaded boot loader
When booting the OVI40 UI a correctly installed boot loader will show this splash screen:
Please also check boot loader version number displayed in system menu corresponds to the version you intended to install.
UHSDR Bootloader further reading
Forum:
Github Wiki:
