  • no UHSDR boot loader present or
  • UHSDR boot loader doesn't work properly
  • If the LCD flickers bright white when switching OVI40 UI on this indicates a bootloader present and working
  • Press and keep pressed switch “Band +”, then apply +5V to OVI40 UI. Text should appear on LCD.
  • Press and keep pressed switch “Band -”, then apply +5V to OVI40 UI. Text should appear on LCD.
Github Doc
You will need:
1. Preconditions
  • STlink software installed
  • ST-Link/V2 adapter connected
  • PC connected to Internet
  • Connect ST-Link/V2 with PC via USB cable
  • SW Utility: ST-Link→Firmware update
  • Check on PC screen in status messages that MCU is reckognized correctly
3. Debug cable
ST-link UI JP8
JTAG-9 SWCLK JP8 Pin 4
JTAG-7 SWDIO JP8 Pin 3
JTAG-20 Gnd JP8 Pin 6
not essential: Signal: Reset JP8 Pin 2
4. Connect
  • SW Utility: Target→Connect
  • SW Utility: File → Open (select the right .bin file, see above). The following screen should appear: (example shows mcHF boot loader)
5. Flash the MCU
  • Write the .bin file onto MCU with Target → Program & Verify
  • In the subsequent windo enter start address:
    • start adresse for boot loader: 0x08000000
  • Then hit start button to program MCU
  • Then program firware in the same manner.
    • start address for firm ware would be 0x08010000
6. Done
These are the correct values:
Read Out Protection: Level0
BOR-Level: Level3
IWDG_SW: gesetzt
WWDG_SW: gesetzt
nRST_STOP: gesetzt
nRST_STDBY: gesetzt
FZ_IWDG_STOP: gesetzt
FZ_IWDG_STDBY: gesetzt
nDBOOT: gesetzt
nDBANK: nicht gesetzt
No ticks set at all in any box below “Flash Section Protection”
  • Also interesting to check list of closed issues.
  • If not found in open or closed issues please discuss on forum - it may not be a SW error at all, so better verify
  • In case you think you discovered a bug not mentioned yet:
    • Please post as new issue in Github. Add additional info as comment, if diiscovered later.
    • Please be patient. All Github members work on this in their free spare time
  • Has MCU be soldered in with correct Pin1 orientation?
  • +3.3V available for MCU? Ground available?
  • TCXO clock available?
  • All connections from MCU to USB ports ok - no shurtcuts, no interruptions?
  • en/uhsdr/uhsdrtroubleshooting.1517935341.txt.gz
  • Last modified: 06.02.2018 16:42
  • by df9ts_user
