UHSDR Troubleshooting
LCD constant white screen
- Press and keep pressed switch „Band +”, then apply +5V to OVI40 UI. Text should appear on LCD.
- Press and keep pressed switch „Band -”, then apply +5V to OVI40 UI. Text should appear on LCD.
MCU "bricked"
In case ST-Link/V2 available
You will need:
- STM32 ST-Link SW utility
1. Preconditions
- STlink software installed
- PC connected to Internet
3. Debug cable
| ST-link adapter | OVI40 UI JP8 | Remark |
| Pin-13 TRACESWO | JP8 Pin 1 | Debug Output |
| Pin-15 NRST | JP8 Pin 2 | Reset |
| Pin-07 SWDIO | JP8 Pin 3 | Debug I/O |
| Pin-09 SWCLK | JP8 Pin 4 | Debug Clock |
| Pin-01 MCU VDD | JP8 Pin 5 | VDD from MCU |
| Pin-20 Gnd | JP8 Pin 6 | Ground |
4. Connect
- SW Utility: Target→Connect
5. Flash the MCU
- In the subsequent windo enter start address:
- start adresse for boot loader: 0x08000000
- Then program firware in the same manner.
- start address for firm ware would be 0x08010000
6. Done
Restore MCU Option bytes
These are the correct values:
| BOR-Level: | Level3 |
| IWDG_SW: | gesetzt |
| WWDG_SW: | gesetzt |
| nRST_STOP: | gesetzt |
| nRST_STDBY: | gesetzt |
| FZ_IWDG_STOP: | gesetzt |
| FZ_IWDG_STDBY: | gesetzt |
| nDBOOT: | gesetzt |
| nDBANK: | nicht gesetzt |
| No ticks set at all in any box below „Flash Section Protection” |
- In case you think you discovered a bug not mentioned yet:
- Please post as new issue in Github. Add additional info as comment, if diiscovered later.
Check for defective hardware
- TCXO clock available?
