Install J-Link Software
Debian SW Install
- Download J-link .deb file, open terminal and go to download folder with terminal$ sudo dpkg -i nameofdebpackage.deb
Windows SW Install
ToDo
Install J-Link in GNU MCU Eclipse
See here
Install Packs
J-Link and Eclipse
Segger Real Time Terminal RTT
- See here
- J-Link adapter seems to support option byte programming via J-link utility and/or J-Flash utility. This is indicated in previous versions of the J-Link or J-Flash user guides, but not in the current ones. See for example section 7.5.1.2 here- ToDo: Verify and try out
ToDo
Further Reading
