  • TRACESWO output as defined by CORTEX M7. This requires a dedicated pin, currently used for M3 pushbutton switch
  • Segger Real Time Tracing (RTT) with outputs debug messages in high speed via SWV debug lines (CLK and SWData). No need for an additional line to printout debug messages
Debian SW Install
Windows SW Install
ToDo
Segger J-Link Configurator - Firmware update tool
See here
Install Packs
  • Install the GNU MCU Eclipse Packs
  • Download CMSIS packs from Keil, see
  • Install local cop of STM32F7 and STM32H7
  • Describe Eclipse seetings (MCU, CMSIS, probe settings, …) to use J-link probe on Eclipse with uHSDR
  • See here
  • See AN08005 (although this is for Cortex-A / Cortex-R and not the Cortex-M used by OVI40 it still gives some insights)
  • Try RTT on UHSDR - is it really 100 times faster than SWO print and 10.000 times fasster than semi-hosting? Segger says here that Cortex-M supports background memory access and that RTT will have no impact on Cortex-M execution speed
RTT target code
Segger J-Link STM32 unlock utility
Further reading:
  • Check Option Byte support on J-Link, see here and here for a starting point.
  • See here and here
  • See 3.12.2 J-Link STM32 Unlock (Command line tool) in J-Link User Guide
  • J-Link adapter seems to support option byte programming via J-link utility and/or J-Flash utility. This is indicated in previous versions of the J-Link or J-Flash user guides, but not in the current ones. See for example section 7.5.1.2 here
    • ToDo: Verify and try out
  • en/uhsdr_dev/segger_j_link.1519481965.txt.gz
  • Last modified: 24.02.2018 14:19
  • by df9ts_user
