Segger J-Link Introduction
Segger provides a probe - J-Link - that can be used for programming and debugging. For non-commercial use Segger offers the low priced J-Link Edu probe.
For Debug output Segger offers an two options in MCU eclipse:
- Segger Real Time Tracing (RTT) with outputs debug messages in high speed via SWV debug lines (CLK and SWData). No need for an additional line to printout debug messages (as is the case with TRACESWO).
The J-Link makes use of the Cortex-M feature, which allows accessing the memory via the debug interface while the target is running. How this works in general is described here.
Install J-Link Software
Debian SW Install
Windows SW Install
ToDo
Segger J-Link adapter Firmware update
As part of the Segger J-Link SW pack the „J-Link Configurator“ utility. In Windows it can be started using the Windows start menu
See here
Install Packs
J-Link and Eclipse
Segger Real Time Terminal RTT
- See here
RTT target code
Calling SEGGER_RTT print from within interrupts / make it re-entrant
During RTT output the functions SEGGER_RTT_LOCK() and SEGGER_RTT_UNLOCK() are called by default in RTT, but the function bodies of those functions are empty and need to be implemented according to MCU used and use case.
Please implement
- SEGGER_RTT_LOCK()
- SEGGER_RTT_UNLOCK()
- .. and disable interrupts and threads which might use RTT in SEGGER_RTT_LOCK() and enable them again in SEGGER_RTT_UNLOCK().
- See [https://mcuoneclipse.com/2014/01/26/entercritical-and-exitcritical-why-things-are-failing-badly/|here]] for a discussion on how to enable / disable interrupts on Cortex-M
Segger provides a „STM32 unlock“ utility as part of the standard J-Link SW pack. The tool can be started in Windows using the „start“ menue and resets all values to factory default:
Note: The unlock utility resets the brown out reset (BOR) to „level 0“, equalling about 1.7 Volt.
Further reading:
- J-Link adapter seems to support option byte programming via J-link utility and/or J-Flash utility. This is indicated in previous versions of the J-Link or J-Flash user guides, but not in the current ones. See for example section 7.5.1.2 here- ToDo: Verify and try out
Flashing MCU with Segger J-Link
As part of the Segger J-Link SW pack the flash utility „J-Link lite“ is provided. Start J-Flash using Windows „start“ button. Note: J-Flash does not support .dfu files. Use the UHSDR .bin files. Load bootloader at address 0x08000000 and load firmware at 0x08010000.
