  • Using Debian version buster/sid
  • Install on Win10 PC with Virtualbox
    • ARM toolchain for Linux
    • GDB
    • Eclipse
    • Check installation with test project
GNU ARM toolchain for Linux
Note: Important: use latest version of tool chain from web sites below. DO NOT use the ARM toolchain that comes with your Linux distribution
$ mkdir -p ${HOME}/opt
$ cd ${HOME}/opt
$ tar xjf ~/Downloads/gcc-arm-none-eabi-7-2017-q4-major-linux.tar.bz2
$ chmod -R -w /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/
  • Test if the compiler is functional; use the actual install path:
$ /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-gcc-7.2.1 --version
  • Output should be like this:
arm-none-eabi-gcc-7.2.1 (GNU Tools for Arm Embedded Processors 7-2017-q4-major) 7.2.1 20170904 (release) [ARM/embedded-7-branch revision 255204]
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
GDB - GNU Debugger & OpenOCD
Check that GDB is installed in your Linux distribution by entering
$ gdb
The output should look like this:
GNU gdb (Debian 7.12-6+b1) 7.12.0.20161007-git
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
If missing install with
apt-get install gdb
Installation:
$ cd ${HOME}/opt
$ tar xvf ~/Downloads/gnu-mcu-eclipse-openocd-0.10.0-7-20180123-1217-centos64.tgz
$ chmod -R -w gnu-mcu-eclipse/openocd/0.10.0-7-20180123-1217
Check OpenOCD installation:
$ ${HOME}/opt/gnu-mcu-eclipse/openocd/0.10.0-7-20180123-1217/bin/openocd --version
Output should be something like this:
GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00404-g20463c28 (2018-01-23-12:24)
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
Install UDEV rules for USB OpenOCD probes:
# cp ${HOME}/opt/gnu-mcu-eclipse/openocd/0.10.0-7-20180123-1217/contrib/60-openocd.rules /etc/udev/rules.d/
# udevadm control --reload-rules
# usermod -aG plugdev $USER
GDB 7.12 distributed with the initial GCC 6.2 (gcc-arm-none-eabi-6_2-2016q4-20161216) has several issues (crashes on macOS and is incompatible with Neon.2). The recommendation is to use the update version gcc-arm-none-eabi-6-2017-q1-update, or later.
Install OpenOCD
$ sudo mkdir -p /opt/gnuarmeclipse
$ cd /opt/gnuarmeclipse
$ tar xvf /home/gerd/Downloads/gnu-mcu-eclipse-openocd-0.10.0-5-20171110-1117-debian64.tgz
  • Test installation:
GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00254-g2ec04e4e (2017-11-10-11:27)
GNU MCU Eclipse and CDT
$ cd /home/gerd/opt/
$ mkdir GnuMcuEclipse
$ cd GnuMcuEclipse/
$ tar xvf /home/gerd/Downloads/20180125-1917-gnumcueclipse-4.3.2-oxygen-2-linux.gtk.x86_64.tar.gz
Make the GNU Arm toolchain location known to Eclipse in Project→Properties→C/C++ Build→Environment→PATH. add the path to GCC here (in this example we would add /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/bin ).
  • Launch eclipse to test installation
Next step: import UHSDR into gnu arm eclipse
  • en/uhsdr_dev/toolchain.1517953249.txt.gz
  • Last modified: 06.02.2018 21:40
  • by df9ts_user
