- UHSDR toolchain installed, see here
Pull UHSDR source from Github, import into eclipse
- Goto https://github.com/df8oe/UHSDR and click button “clone or download”
- Unpack the downloaded .zip file on your hard disk. Do not change the name, do not change the internal zip structure
Build UHSDR using eclipse
- Project → Build Configurations → Set Active → DebugLibOVI40 (OVI49 DSP Library (STM32F7))
- Click on the “hammer” in the tool bar
- Watch Console window in Eclipse - if all ok console output ends with ” … Build finished …“
- Project → Build Configurations → Set Active → DebugOVI40 (OVI40 Firmware (STM32F7) …)
Download new firmwar .bin to OVI40 UI
- UHSDR FW build should run.
- Hit switch “Menu”, then select “System Info” and “Build”. Check the build date and time corresponds to your compile time in eclipse approximatelly
Generate .dfu file from .bin file
Eclipse user guide
Debug, tracing, real-time diagnostics
- J-Link Debug Probe here
Further reading
- SWV and SWO and Eclipse explaind here
