npm install xpm --global
Install PAckages CMSIS
      • Ín left window, click once on STM32F7 series. Then above middle window click yellow box icon to install a local copy of the selected package
      • In left window, do same with STM32H7 series, download a local copy
  • en/uhsdr_dev/win10_toolchain.1518866116.txt.gz
  • Last modified: 17.02.2018 11:15
  • by df9ts
