npm install xpm --global
Install PAckages CMSIS
      • Install STM32F7 pack
ToDo next: Git integration
  • en/uhsdr_dev/win10_toolchain.1518886120.txt.gz
  • Last modified: 17.02.2018 16:48
  • by df9ts
