en:uhsdr_dev:win10_toolchain
npm install xpm --global
Install PAckages CMSIS
      • Install STM32F7 pack
    • Set/check that active project is correct
    • Set/check that device is correct:
      • For OVI40 with F7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32F767ZI
      • For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI
  • Download Github desktop from https://desktop.github.com/
  • Start Github Desktop, enter your Githu username and password, clone repository “https://github.com/df8oe/UHSDR”
  • Optional: create local branch of cloned repo for tests
  • In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository
  • Check Eclipse settings for
    • active build config
    • MCU device used
  • en/uhsdr_dev/win10_toolchain.1518895788.txt.gz
  • Last modified: 17.02.2018 19:29
  • by df9ts
