npm install xpm --global
Install PAckages CMSIS
      • Install STM32F7 pack
    • Set/check that active project is correct
    • Set/check that device is correct:
      • For OVI40 with F7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32F767ZI
      • For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI
  • in Eclipse Help→check for updates
Option: Github Desktop
  • Download Github desktop from https://desktop.github.com/
  • Start Github Desktop, enter your Githu username and password, clone repository “https://github.com/df8oe/UHSDR” * Optional: create local branch of cloned repo for tests * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository * Check Eclipse settings for * active build config * MCU device used * … === Option: git commandline === * create directory where UHSDR repository should reside, e.g. d:\uhsdrgit clone https://github.com/df8oe/UHSDR ===Import git UHSDR project into Eclipse installation === * In Eclipse, choose “File→Import”. * .. then choose “General→Existing Projects into Workspace”. * Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory” * The project is now recognized and can be imported * Next: check Eclipse settings
  • en/uhsdr_dev/win10_toolchain.1520933499.txt.gz
  • Last modified: 13.03.2018 09:31
  • by df9ts_user
