fr:uhsdr_dev:uhsdrbuild
Cette traduction est plus ancienne que la page originale et est peut-être dépassée. Voir ce qui a changé.
  • UHSDR toolchain installed, see here
  • Goto https://github.com/df8oe/UHSDR and click button “clone or download”
  • Unpack the downloaded .zip file on your hard disk. Do not change the name, do not change the internal zip structure
  • The project is now recognized and can be imported
  • Project → Build Configurations → Set Active → DebugLibOVI40 (OVI49 DSP Library (STM32F7))
  • Click on the “hammer” in the tool bar
  • Watch Console window in Eclipse - if all ok console output ends with ” … Build finished …“
  • Project → Build Configurations → Set Active → DebugOVI40 (OVI40 Firmware (STM32F7) …)
  • User guide can be found here.
  • Profiling is described here
01.02.2018 23:12 · df9ts_user · 0 commentaire
  • fr/uhsdr_dev/uhsdrbuild.txt
  • Dernière modification : 09.02.2018 08:15
  • de df9ts_user
