OVI40 V1.8 UI - Bau
OVI40 UI V1.7 Unterlagen
OVI40 UI V1.8 Unterlagen
OVI40 UI V1.8 Bausatz Inhalt
Zusammenbau und Bestückung
BAV70 | A4 | D5, D6 | Diode |
MCU STM32 "Pin 1" Markierung
Vergleich derMCUs:
RAM [kB] | 192 | 512 | 1024 |
Takt[MHz] | 168 | 216 | 400 |
Pins | 100 | 144 | 144 |
DMIPS | 210 | 462 | 856 |
EEPROM IC7 orientation
Polarised capacitors
- „mcHF style“: S7 and S8 not line with switches under LCD - they are mounted slightly higher
- „OVI40 style“: S7 and S8 are mounted in line with the function keys under the LCD
„In line“ is the preferred mounting location for S7 and S8.
Modifications
Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: Put resistor in parallel to C94. Start with a value of 56k - this seems to work in most cases. If board does not start increase value slightly.
Change brightness of LEDs
- R36 auf 22,6k (D1 grün)
- R37 auf 6,8k (D2 rot)
- R116 auf 6,8k (D3 blau)
Diskussion
Vy 73 de Michael, DL2GMI
Gruß Gerd DF9TS.
Bis dahin etwas Geduld bitte.
Gerd.
