UI-Platine:
| BOM OVI40-SDR UI V1.7 | 24-09-2017 | DF8OE | Distributor / Prices | |||||||||
| Part | Value | Description | Package | Amount | FARNELL | Price | Reichelt | Price | Mouser | Price | Digikey | Price |
| IC8 | NCP5501DT50G | 5,0 Volt LDO | DPAK | 1 | 170-3369 | 0,602 | TS 2940 CP50 | 821-TS2940CP50 | ||||
| D1 | green | LED | LED_3MM | 1 | 276-4976 | 0,409 | LED 3MM ST GN | |||||
| D2 | red | LED | LED_3MM | 1 | 276-4977 | 0,361 | LED 3MM ST RT | |||||
| D3 | blue | LED | LED_3MM | 1 | 276-4975 | 0,443 | LED 3MM ST BL | |||||
| BAT1-HOLDER | Battery Holder CR2032 | 1 | 188-5903 | 2,98 | BU2032-1-ND | 0,66 | ||||||
| L1 | 47uH | L_SMD1005 | L1005 | 3 | 221-5655 | 0,13 | MLZ2012M470WT000 | 0,12 | ||||
| R1 | 47k | SMD Resistor TK50 | 0805 | 6 | SMD-0805 47k | 0,02 | ||||||
| R1A | 100R | SMD Resistor TK50 | 0603 | 13 | SMD-0603 100 | 0,03 | ||||||
| R1B | 0R | SMD Resistor TK50 | 0805 | 9 | SMD-0805 0 | 0,02 | ||||||
| R2 | 1k | SMD Resistor TK50 | 0603 | 7 | SMD-0603 1,0k | 0,03 | ||||||
| R3 | 100R | SMD Resistor TK50 | 0603 | 2 | SMD-0603 0 | 0,03 | ||||||
| R4B1 | 2R2 | SMD Resistor TK50 | 1206 | 4 | SMD ¼W 2,2 | 0,03 | ||||||
| R9 | 4k7 | SMD Resistor TK50 | 0805 | 4 | SMD-0805 4,7k | 0,02 | ||||||
| R10 | 4k7 | SMD Resistor TK50 | 0603 | 1 | SMD-0603 4,7k | 0,02 | ||||||
| R13 | 47R | SMD Resistor TK50 | 0603 | 7 | SMD-0603 47 | 0,03 | ||||||
| R23 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
| R24 | 680R | SMD Resistor TK50 | 0805 | 4 | SMD-0805 680 | 0,02 | ||||||
| R35A | 4R7 | SMD Resistor TK50 | 1206 | 1 | SMD ¼W 4,7 | 0,03 | ||||||
| C10 | 100nF | SMD Chip Capacitor X7R | 0603 | 62 | X7R 0603FCF 100N | 0,04 | ||||||
| C100 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
| S1 | G3 | SMD Pushbutton KSC941J | 19 | 243-5157 | 0,64 | CKN10433CT-ND | 0,55 | |||||
| S19 | not assigned yet | SMD Pushbutton KSC941J | . | |||||||||
| J1 | 1503_07 | Audio Plug 3,5mm | 1503_07 | 3 | 121-7016 | 2,26 | LUM 1503-07 | 0,59 | ||||
| Button Cap | Cap white | BTNKSC980 | 11 | CKN10427-ND | 0,27 | |||||||
| IC9 | CY15B104Q | SPI FRAM | SO08 | |||||||||
| IC11 | SST25VF04B | SPI FLASH 2,7V, 4Mbit | SO08 | SST 25VF040B | 0,97 | SST25VF040B-50-4I-SAF-N | 0,82 | |||||
